Pump pedal hard with engine off til it goes stiff then hold it down, as you start the engine it should sink a couple inches, then switch it off and pump and should go stiff again.
If the above dont happen then could be your problem
this happens with mine also but only while moving (like slowing down to a traffic light and while in neutral)
brakes seem to lack the initial bite (discs and pads are one good-ds 2500+ brembo HC combo) could these two issues be related?
Haha. Quality. I had a Fiesta years ago and the revs used to die every time you put the clutch to the floor. This resulted in me having to press the clutch, brake and tickle the throttle every time I rolled up to a junction, all simultaneously.
