Hi
Last week i bought myself a 172 Cup and today its started giving me problems
Took it out this morning, was a little hesitant at first and a bit jerky but was ok after a mile or so, drove around quite a bit, then home.
Went to take it out this afternoon and the acceleration is very rough and jerky, it sounds almost as if its misfiring, it idles and just under 1,000rpm just fine though, its not until you press the accelerator you hear and feel the roughness.
Took it few hundred yards and engine management light started to flash, so i pulled over and turned off.
Then re-stared but it kept happening, EML will flash for a bit then stay on solid for a while then flash again etc etc...
Checked the usual, oil levels fine, oil looks clean, water level fine, no pressure in header tank. Check connection of HT leads on coilpack.
Where are the sparkplugs? does the inlet need to come off to access them?
Any help would be massively appreciated!
Ash
Ash
