Car Select Warranty
Has anybody had any dealings with an extended warranty provided by Car Select?
My mind needs putting to rest - Cambelt needs replacing at 33000 miles :o
I cant afford to be out of pocket this month :cry:
are you sure the cambelt needs changing at 33k, my mk2 172 is on 35k and you got me worried .
Erm yes... well mine only.
The tensioner is visually misaligned resulting in damage.
Has been diagnosed by Renault today and judging by the noise the car makes Im pretty sure!
Apparently its a common problem on the 172 engine - took that comment with a pinch of salt though.
doh! shud read all of thread b4 posting
erm now i cant use my mouse, ive gone all cabbaged (cant spell either)
Normally the cambelt is changed on the 72k service but as he said his needs doing for other reasons. Read the small print but Id be guessing a cambelt would be classed as general wear and tear, if it snapped it would be a different thing altogether.
Errrm..................I wouldnt call that wear & tear............but thats just me eh :D
Cya Stu
Just had a call from the service manager at my local Renault dealership, turns out when Car Select sold me the car they replaced the alternator however did not fit it correctly - (bracket). This has twisted therefore causing damage to the tentioner and so on. The cam belt is not being replaced luckily but im still going to be out of pocket for another £250 because of their incompetance :cry:
Im not happy being informed that ive been driving a potentially dangerous car since August last year :@
Must of been missed on an MOT test too.
Reckon its worth kicking up about?
It prob wouldnt have needed to be checked on MOT test, you would be suprised by how lax a test it really is, you can get away with alot at MOT.
You better believe it you cant accept this and say nothing..........Id be hauling them over the coals BEFORE they even start the work and I with a manager for sure :D
Go for it but keep your cool...........dont get all hot and bothered cause they will just take the hump then you will be up against it eh ;)
Cya Stu
