Paddy_g46
as title says im doing a test on the hybrid lump in the car im off 2 see tomorrow, what readings should i be looking for?? and should all 4 cylinders be exactly the same or can they be a bit out and not worry about it???
also is the procedure
1) warm engine up to moraml temp
2) disconnect lead from coil (the lead the feeds all the ht leads)
3) remove first spark plug and attach tester, turn engine over on key for 5-10 seconds, record reading, replace spark plug
4) remove plug 2 etc
5) test all 4 cyclinders ans compare readings
is that all the steps????
