CD PLAYER PROBLEM
Car  172
[h=2]Hi as above since having the battery disconnected to do the clutch etc i can't seem to enter my security code, it keeps coming up with ERROR rather than the 4 zero's, standard reno tuner list job, i have tried disconnecting the battery again for a few mins but to no avail just wondering if anyone else has had this problem and managed to sort it[/h]
cheers​
Hi there.
You need to leave the ignition on.
The errors occur after an incorrect radio entry, it will then double in time every wrong code you enter.
The only way to get rid of the error is leave it turned on, stage 1 on the key!
Sam!
Hi there.
Sam!
arrgh brilliant cheers for that i was about to reserve a new head unit at Halfords to pick up after work, cheers mate much appreciated
