is there a guide to removing the center consol all the way from the handbreak up to the cd player?? Also how do i remove the A-pillars there a sensor each side and i dont know if i just pull them off?? do i :S
Top of the dash (Where the clock is, the cover over the speedo and over the passengers airbag) comes off. About 13 screws (I think) to undo, including the steering wheel cover that has to come off as well.
The sensors on the A-pillers will just pop away from the U bracket they're on.
the sensors have to be unsoldered as the wire is fed through to the base of the sensor which is screwed on to the A pillar before the cover is clipped on.....
The A pillars have to be removed first before removing the dashboard top. There are a couple of guides in the "guides" section on removing the dash.
