Centre bore of 2118's ???
Is the centre nore of a clio hub 60.1 mm?
Also i need to find out the centre bore size of silver speedline 2118's
Well i do cos they dont fit!
There silver ones 6J ET30, someone told me i can find the bore size stamped on the wheel itself, i didnt look to be honest and now I have stored them away. Is this the case?
ill get a vernier gauge and measure it up and get the spigot rings on order.
Yes they are 6" wide alloys with an ET30 offset
2118's in Renault fit is 7 x 15 in either ET43 (iirc) and ET38
ET30 it going to be very close on the back arches and their a inch less wide than even stock.
Seriously, don't bother
Just had a look mate. At least you know they won't rub with the offset and fit fine. If you look at Nick's post SirDave i think it is says the bore is 70 on these wheels. Double check it tho
Surely the bore on the wheel is going to be speedlines standard size say 70 and you just request the 60.1 spigot or even just renault spigot from speedline or ebay?
