Changing a flywheel on a 172
Car  Clio 172
Hi I need to swap the flywheel on my 172 as I'm doing an engine swap & when I try bolt the clutch on the fresh engine the bolts won't tighten up on the existing flywheel, I want to fit the flywheel off my old engine but wanted to know if it requires fitting in a certain position or will only fit in a certain position etc before I go pulling it off.
Thanks Matt
