Changing dials 1.2 16v
Martin_172
hi, i might be able to get my hands on a set of the phase 3 dials, the one with the screen to replace the coolant temp and fuel guage.
was just wondering if they are a straight swap for my dials ie. no extra wiring. also my car doesnt have a trip computer so would i just have to change the steering stalk and i could use that?
Also what about millage, how can i get it corrected to what my car has acctually done?
cheers.
Has
  RS 182 - Black Gold
No its not a simple swap over.
The wiring is slightly different.
Millage cannot be adjusted
and trip computer wont work, only Dynamique models have them IIRC and other models around that type
Martin_172
i thought the trip computer was built into the dials though? so you juts needed to change the wiper stalk so you had the button on the end (just a thought)
im not changing dials if i cant adjust the millage though, because it looks kinda dodgey when it comes to selling the car since im at 118,000 miles
cheers for the help
Has
  RS 182 - Black Gold
No probs,
No itsall calculated etc from the carnot the dials.
just by changing the stalk wont give u the use of it etc...
bit of a hi-jack, but i have a really early mk2 ph1 - with all the trip computer etc. - would the later sets of dials with the BIG rev counter work in my car?
Has
  RS 182 - Black Gold
Duck - different connector on the back of it.
(have seen the backs which differ)
Martin - u can get them re-done but yes it is costly!!
If u actually speak to them, some Clio II clocks cant be changed,
  172 cup'd extreme
Has is right, some clio 2 clocks cannot be adjusted for milage due to them having a back up ROM on the board.
the trip wont work as its programmed into the ECU and a different wiring loom for the clocks the connectors are the same but the pins on the blocks are different
