Changing rear shockers...?!
Car  ClioSport 172
I've been told this is an easy job. Does any1 know where i can find a step by step guide....just to keep me right. Many thanks.
Mhmm...i cannot seem to access that section. Says i don't have sufficient privilages too access it.
Here it is.
I may get shafted for copying this but here it goes.
Lol :rasp:
Have had these photo lying around for a while. Simple task to change these but a few pictures might help a few more.
Required:
Jack
Axle stands
17 & 18 Spanner
New dampers
Jack the car up and put on axle stands
Open bottom bolt with 18 spanner (blue mark on it here)
Remove top mount cover and take off nut with 17 spanner
Old damper will fall out. Line up new damper, insert and tighten it all up.
Done.
You may need a small adjustable spanner/vice grips to dtop the shocker rod (chrome rod) turning when removing the top cap and nut. ;)
