Changing spark plugs on 1.2 16v
  Fabia VRS Special Ed
This might sound a bit stupid to some, but I've taken the HT leads out, looked down and the Spark Plug is sitting about 6 - 8 inches down the pipe, I have a 10mm spark plug socket to remove & fit the new plugs, but it's too wide to get down the pipe, what the f**k do I do? :rasp:
  Ph2 172
I have one mate. Did my bros 1.2 few weeks ago. I'm not far from you either if you wanted to pop down.
Right...update....Bought the "Specialist" tool from Renault that was needed (robbing fcukers) and set to work on the plugs, did the first 2..no problem, came to the the third and the plastic bit that sits inside the HT lead & over the spark plug has come off and is now stuck to the spark plug, so now I can't get it or the spark plug out....Any ideas?
Just to say that I did the last plug (skipped the dodgy one) and that fitted fine....Took the car for a spin and it was hugely improved, but want to get the last one in obviously!
Help is very much appreciated!
Liam
  E36 Coupe & Mk4 Golf
This sounds dodgy, but i once just forced the socket over and undone it, however i was changing the leads aswell
M
mini-valver
As above, long nose pliers but you'll need long handled ones. Had it happen a few times!
Fixed it guys, it was the rubbery bit right at the bottom so it was about 7"s down the thin tube so had to use a wired coat hanger (the future) to get it out....Replaced all spark plugs & HT leads now....drives much better and MPG has shot up!
Cheers guys
Liam
Liam
The garage I used also done this on the 3rd spark plug! Must be common!
For peoples reference, Halfrauds do a 8mm (14mm Euro) socket 250mm long with a 3/8" Drive for about a tenner. This is whats needed for the job. Made by laser as detailed above^.
  Astra 1.9Cdti SRi
Or just use a normal deep socket and use some long nose pliers to pull them up, no point gettin the "proper" tools,
