Clio MK3 1.2 16v Clutch Change - Incorrect size pipe for CSC
  Clio 1.2
Hi,
I've spent the weekend changing the clutch on my Clio MK3 1.2 16v. I bought the recommended LUK 3 part clutch that stated it fit this car. However, once I had fitted it back together I went to plug in the clutch pipe into the Concentric Slave Cylinder (CSC) and I noticed that it didn't fit as snug as before. It seems that the CSC is a 13 mm female hole and the original is a 12 mm. I wondered if it is possible to change that lower length of clutch pipe, from the mid connection to the clutch, so that it will fit to the CSC? That would save me buying a new CSC and fitting it all over again.
  Clio 1.2
Anyone know which clutch pipe fits into the 13.3 mm CSC? It looks like it's either 8200227585 or 8200858945 from looking at the part manuals, but they don't provide any specific sizes.
  clio and passat
I have the same problem. Would you be kind enough to let me know if either fit or how you solved it? Thanks
