'Check injector' help!!
Car  Renault Clio 1.4
Hi,
Took the leap and signed up great forum!!
I've been getting a check injection warning message accompanied with the flashing check engine symbol.
I have so far replaced the plugs as well as all for the coil pack. The engine still runs pretty sluggish and the Rev count is pretty high.
I have received the following diagnostic messages:
Cylinder 4 misfire detected,
Misfire detected with low fuel,
Injector circuit/ open cylinder 1,
Random/multiple cylinder misfire detected.
I own a 1.4, 55 plate Clio dynamique. Any ideas would be greatly appreciated.
Researched a little and only other idea may be lambda sensor? Check emissions warning did appear briefly but has since gone when coils were replaced, also ran the injectors cleaner through the fuel tank which wasn't much help.
Thanks in advance
The injectors need replaced/ultrasonicly cleaned.
Tbh I'm not sure why you've replaced other things when the code is telling you what's wrong!
Check the resistance of the injectors, I had an injector short/open circuit fault and was of mine was faulty!
