Urgent- Clio 182 not starting at loton park
  Clio 182
URGENT - Clio 182 blowing 30A engine management fuse, crank no start at Loton Park
Hi all, currently stuck at Loton Park hill climb and need some urgent help.
Car completed a run fine, but when I got to the top and slowed down the engine stalled itself while still moving. Since then it will crank but not start.
Symptoms:
  • Cranks strongly
  • No spark/fuel
  • Rev counter does not move while cranking
  • Electronic fault light on dash
  • 30A engine management/injection fuse blows instantly as soon as ignition is turned on (before cranking)
Things checked:
  • Found loose gearbox earth strap and reconnected it
  • Checked battery terminals
  • Checked crank sensor plug
  • Unplugged lambdas, alternator, coil pack and injectors one by one
  • Still blows fuse instantly
Seems related to injector lockout/injection relay circuit.
Does anyone know common places on a Clio 182 loom to short/blow this fuse? Need to try get it going today if possible.
Thanks Archie
Brigsy
  T.Turbo
Fuse blowing instantly indicates a short to earth. Lambda wiring all good pre sensor and not melted etc? Try unplugging vvt etc in the off chance something has died and shorting out.
