Hi all. My friend bought a 99 clio 2 1.6 auto about 2 weeks ago. She got it from a family friend and knows that it has always been reliable and never had any major problems.
The problem started when the car started to cut out after about 15min of faultless driving and then fail to restart until left for a few hours. It always seemed to cut out when idle or changing from drive to reverse never when at any speed. I thought that it might be overheating but the cooling system is working fine so it has to be electrical.
Now it will not start at all and there is no spark from any of the ht leads. I swapped the coil packs and it still will not spark. The engine turns over fine and the battery is fully charged. I then checked the wires on the coil pack connectors with a multimeter and now I'm confused. There are 2 coil packs and each has a connactor plug. Each connector plug has 3 wires and on both plugs two of these wires are giving 12v and the other one nothing.
I checked the same two plugs on another working car that I swapped the coils from and with the igniton on 1 of the 3 wires is giving 12v and the other two nothing.
It looks like the ecu is putting 12v on one of the wires that should not be live, or only live when the coil packs are supposed to fire?
Can anyone help as I'm about t0 go and spend a load of money on a replacement ecu.
Ed
Ed
