Citrus Snow Foam
  Honda & VW
As i was getting low on my snow foam i recently decided to try the 'Citrus Snow Foam', to be honest i am not all that impressed with it as i have always used this and always found it to be very good (very thick foam).
The Citrus foam came out more like a thin/soapy foam than what i am used to, no matter how much i played with the lance dial etc i could not get the same thickness.
Granted the foam did stick fairly well to bodywork just not in the normal thickness.
To be honest i havent really played around too much with the dilution ratios at i onyl tried it out yesterday for the first time, so can anyone suggest/recommend the best ratio to ensure thick foam or is the Citrus stuff just not that 'foamy'?
  Honda & VW
^ Yeah is does its job just doesn't produce 'Thick foam' as its stated to do. Hasn't got the same wow appeal when neighbours drive past and wonder why there is a car emerged inside a massive blob of Foam on my drive lol
  Bumder With A Buffer
Buy Magifoam from autobrite.
The citrus stuff I have also doesn't foam "that" well.
I use An inch of foam, a drop of either britemax shampoo or APC and top up with hot water. It foams better a bit using the other additives
