Cleaning INSIDE my headlights?
  Megane
6 years on, they are pretty full of s**t, dont know if i should bother cleaning them, is it possible to do?? Will the dust build up quickly?
  A well built VW
Im pretty sure you can bake these in your oven and they will come apart but you will need silicone to put them back together and then im pretty sure they will leak
What about if you take them out and use a high pressure air hose to clean the s**t out of them
  www.renparts.co.uk
they're epoxied, you won't get them apart without smashing them. Ph1 headlamps you can take apart, black adhesive, put them somewhere warm/go steady with heat gun and they come apart.
