Climate control question
Can anyone tell me, when you have it set to auto obviously everything is set automatically, vents, temp, fan speed etc., but if you do not have in on auto, because you want a different vent set up, (which turns it off auto) does it still control the temp or is it like a normal heater set up where you have to keep adjusting the temp.
You just press the red button to get it to the next temp you want, blue to reduce the temp.
If you press the auto button this just means that it will return to what you had it set on before you turned if off........Does that help????????????????
Rob.
No not really, if you want a different vent to work, say for instance the ones facing you, and they are not open when it is on auto, if you select them, this will turn it off auto, so does this mean that you have to keep adjusting the temp as it is not in auto
thanks del
