climate control .
  renaultsport 172
popped the climate control on today, was still on max temp after last weekend wanted to turn it down and pop the air con on...
i turned it down to min temp but its still blowing hot air?
cold blowers/air con worked fine no less than a week ago
any ideas?
thanks
ph2 172 by the way
  Volvo S60 T5
Air conditioning low on gas I expect, or you may have a fault temp sensor either the one inside the car near the rear veiw mirror or the one on the outside of the car.
Best to get it on a proper Renault Clip system as this will tell you which it is.
  renaultsport 172
i wouldnt of thought it would be the gas, it blows hot air on low temp even with air con off?
will take it wen i get a chance!
