clio 1.2 16v 53, lacking power and misfiring.
Mavez
  Clio & No Megane
Hey there,
Car started randomly missing and lacks power (more than usual ;D). I've had the engine management light on the dash come up and hooked up the scan gauge to it which read out a P0203 code which is injector on the 3rd cylinder. I've put a different set of injectors in, changed sparks and coil pack 5000 miles ago. Checked all wiring looks fine and nothing looks out of sorts.
It's not feeling as bad as it did when I cleaned and changed the injectors but still when you try to push it, it will hesitate and judder, and under idle it will still randomly miss.
Now am thinking car was fine until my dad used it and filled it up with fuel, could bad fuel cause these symptoms?
any ideas appreciated ;)
Neil M
