Clio 1.2 8v wont start after new battery today lost all power and slowed to a stop
  Clio 1.2 04
Re: Clio 1.2 8v wont start after new battery today lost all power and slowed to a sto
What my uncle said:
Right it could be a faulty relay have a look in the fuse box there will be 2 relays, try swap there over see if it starts. One of them will be the fan
worth checkin ?
  RS6 C7
I always run all my cars to the last little bit, I doubt that would be the cause. I had 0 range earlier in the Audi.
  Clio 1.2 04
Yeah true, for the 2 months i've been passed i've done the same
  Clio 1.2 04
I have just fixed the exact same issue on a clio, i cant be 100% sure as every case is different but the way i cured it for someone was change the relay. What happens is rust & water gets into the fusebox under the bonnet.
You may need to go to a scrappers & get a new fusebox or relay.
tdc sensor prob mate i work for a main renault dealer pitty u dont live ner me i coulda sorted it out or fuel pump relay . as long as ur timing belt is not snaped
what other people are saying any input?
  AB182, Audi A5 3.0
have you checked for a spark? If there is no spark, then it could be your coil pack. This is where I would start...
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
It could be a fair few things... Cheap code readers work in these situations.
