Clio 1.2 starting problem
welshname
So I've just put the car back together after changing the clutch and I've got this.
I've checked the earth from the gearbox which would be the obvious one but last time this happened it just magically went after 5 mins of trying. This time it's not.
What other things can I check?
Thanks.
Try syncing the key again:
"The tip to sync the immobiliser again was to have the key in the ignition and turned all the way on, hold down the internal locking button until it beeps (5-15 seconds), take the key out, lock and unlock the car using the button on the key, put the key back in and start the car!"
welshname
On the back of it. Then if I'm not mistaken it earths to the gearbox through the bolts but the initial earth wire goes on the back of it which is what was dodgy
