I have a Renault Clio 1.5 DCI 2002 65BHP
My TDC PIN Bolt has been rounded, I need to remove to lock the Crankshaft when doing a timing belt, according to Renault Tech. Instructions
I’ve had no luck trying to remove this using a reverse drill and Screw Extractor.
Can anyone advise please if I can do the timing belt replacement and water pump simply by locking the Camshaft and having the Crankshaft set to 12’oc’clock and marking these alignments?
I’ve read TDC cannot be done this way, due to the Crankshaft not being keyed and my engine having free floating crankshaft. But I’m not sure what this means.
Are you able to advise on this, or give any hints please as to what you would do?
What would be your approach?
What is meant by not keyed? and Free Floating pinion crank?
thanks in advance
thanks in advance
