Clio 1.6 odd Horn problem
Car  182 Trophy
Hi Guys
Got a problem with a 1.6 Clio (55) ...
The car was opened the other morning and all of a sudden the horn started to sound continually. I’m pretty sure the car has no alarm and also it was as if I had my hand held on the horn. This continued for around 5 minutes and stopped. Then the car started to be driven and the horn beeped another few times but this time didn’t stay on. At first I thought it was an alarm issue but I’m pretty sure that
A. The car does not have an alarm
B. The alarm would not be a constant beep (as if you held your hand on the horn continually)
Now when I press the horn nothing happens whatsoever .... Does anyone have any idea what the problem could be ? I’m going to get hold of another horn to try but i can’t see that causing the horn to go off this morning like it did ?
Sam
Sounds like loose wiring on the horn circuit to me or possibly wet wiring inside the arch maybe?
J
Ahhhh this sounds like a nightmare :-(
Im going to get another horn to plug in to see if it works, at least then ill know if the current horn is ******
This could be a real nightmare ...
Someone has suggested that it could be the relay ?
Anyone heard of this before, where is this located and how do i change it
Sam
Try removing the steering top shroud (just give it a good tug) in there you'll see the airbag and horn connections mine have ripped themselves off the terminals and i had to solder them back on.
hope this helps
