Clio 172 conversion guidance
Tomo3292
Car  Clio 1.6 K4m
I am currently converting my 1.6 K4M into a 172 and need some guidance on the following.
What's the difference between 1.6 and 172 lower wishbone Arms??
Can I mount these onto the 1.6 subframe, and use Strongflex bushes, or do I need a 172 subframe.
Will I need 172 coilovers as I'm guessing the 172 hubs im going to be using will have a different hole spacing diameter.
Thanks in advance
I remember reading some advice being given to a guy wanting to put a gti engine into a mk2 golf "Never build a car you can buy".
With good 172s costing 1-2k why would you go to the effort of converting a normal Clio into a sport.
Good luck anyway if you carry on with it
Simple reason is I know for a fact I can do it for much less than 2k, to a better than standard state.
Most things will be upgraded as it started as a 1.6 rally car.
Kind of undesand where your coming from, but most of it has been done hence the reason I didn't wanna buy another 172 car.
All the electrics are there ready for the 172, so all I need is engine and box and suspension parts.
