IW365
Clio 172 cup 2002
Hi all,
I've had some sound advice in the past from people on this forum, so here goes with another question or two...
My 2002 clio 172 cup which I have owned from new had a timing belt slip at 140k causing damage to the head which after a lot of deliberating I had repaired. I had a couple of years of trouble free motoring until it developed a misfire which my mechanic diagnosed as a potential problem with the inlet valve(s) in cylinder 1, but this could not be proved without stripping the head down.
To cut a long story short I needed a reliable car for work so I bought a Civic type-r and left the clio in my garage for a year.
Anyway, I miss the clio, so I want to get it back on the road and (probably misguidedly) I've started to strip the engine. My technical skills are fairly limited and I've probably reached the limit of what I can do (next step is to remove the belts and rocker cover), so my questions would be:
1, should I persist with the head removal and have it rebuilt?
Or
2, get a new engine fitted?
Or
3, sling everything in the boot and sell it as a non runner?
If anyone has any advice, or can point me towards someone local to Cambridge who can help I'd be really grateful.
Ian
Or
Or
Ian
