Clio 172 F4r736/F4R730
  clio sport 02
Hi,
Does anyone know if the F4R730 and the F4R736 have the same valves/cambelt set/rockers/waterpump?:approve:
  clio sport 02
Hi thanks for the reply,
what im thinking is that the 730 comes out of a ph1 172 and the 736 is ph2 172,
are the internal parts the same which i think they are?
Are the cambelt sets the same? this im really not sure.
  Golf GTD Mk7
They are pretty much identical engines so I would assume the cambelt would be the same. Hopefully one of the traders will confirm. All internals are the same (cams I think are) iirc
  Yozz'd up 182
ph1 172 head is different.
As is ph2 172 and 182 differ from each other.
ph1 has different ports iirc? slightly larger exhaust ones?
also i believe ph2 172 and 182 heads differ and the inlet manifolds are not switchable one way beacuse of something to do with the oil breather hole?
I think thats right anyway
  clio sport 02
Ok,
this is what i wanted to do,
buy these for my F4R 736
Item # TEV-1280 http://www.trechii.com/products.asp?cat=337
Item # TIV-1279
http://www.trechii.com/products.asp?cat=344
Item # THS881B http://www.trechii.com/products.asp?cat=263
Rockers http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=140390488966&category=63719&_trksid=p5197.c0.m619#ht_1876wt_901
They all say F4R730,
I have asked on the Renault forum they say the main internal parts of the block are the same and that the external parts are the ones that differ which gives you the different code!! not sure now?
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
Basic blocks and internals are the same, cam profile is also the same as are the water pumps. The timing belts are the same BUT the idlers ARE different between the Ph1 and Ph2.
