Clio 172 Ph1 bad idle, revs don't drop after clucth
  Clio 172 ph1
Hi, I have a problem with my PH1. idle is 1100 rpm, or even higher sometimes. Also the revs erratically go from 1500 - 2500 after pressing the clutch while driving. Then sometimes revs stay at 2000 ,sometimes lower, sometimes higher.
After reading the forum I tried changing:
  1. Idle Control Valve (new)
  2. Intake Gaskets
  3. Searched for air leaks (none found)
  4. cleaned the throttle body and lubed it multiple times - it moves freely without sticking.
I noticed some axial slack :
Is this the reason ? Any Ideas how to fix it ?
Please help, it drives me crazy... Thank you.
