R29TJR
2005 RB 182 Cup
Good Afternoon All,
I'm toying with the idea of removing the AC & HPAS in my Clio 182 Cup. Firstly this car is only used for track/fun driving and will only do a few thousand miles a year.
I would look to replace the power steering with an EPAS set up (DCI column, return pipe on current rack, plugs & ebay EPAS set up) and ideally run a 172 Cup alternator set up, plus I'm still missing the bolt which I believe has been discontinued.
However this set up isn't going to come cheap...
Including a new alternator I'm looking at spending around £300.00 in the new alternator set up and then around another £100.00 for the steering set up so all in all I'm looking at around £400.00.
If that's the cost then so be it but I just wanted to ensure I hadn't missed any other options.
I may try to to fix my current set up currently leaking from the joint by the alternator but if that is going to cost me the pipe cost I may as well look to do the above set up.
Thanks in advance.
Tom
Thanks in advance.
Tom
