Clio 182 Vibrates After Trackday
  Renault Clio 182
Hi Guys,
After a trackday my car started to vibrate while accelerating. This happens after 2k rpms and the power of the vibration depends on how much I accelerate.
Have you ever experienced this issue?
Should I park the car until I find out what the problem is?
Ty for your help!
Martin_172
as above, wheel bolts and check the front drive shaft nuts to make sure they are tight, play in the bearings can cause a vibration although its noticed more during cornering
  Renault Clio 182
The car’s suspension (I think) is fine. There is noticeable vibration while going in neutral.
Martin_172
if your getting it in neutral it could still be a driveshaft/bearing
put it in neutral so its making the vibration and give the car a rev and see if the vibration increases with revs, that will tell you if its somthing after the gearbox or somthing before it
