clio
Hi everyone,
I joined the forum to see if any of you kind souls could help me out with my dilemma.
I have a 2002 1.2 Clio and when I bought the car last week, the driver side window didn't work but the passenger side did.
I took the motor and regulator out and it seems as though it is trying to move as it does move slightly either way when pressing the switch. I connected it up directly to the battery and it moved either way fine.
My thoughts were that it may be a broken/bad connection whether that be live or earth.
I really am at my wits end with it as it can't be the motor and it surely isn't the switch as it is moving (if only slightly) when pressed. It's like it isn't getting enough power through to is as when it has a direct feed it moved no problem.
Any help would be appreciated.
Cheers,
Tommy
Cheers,
Tommy
