Clio aerial cable
ive had my alpine head unit in for a while but never been able to use the tuner cus the signal is so damn sh*te. I think its the actual cable itself cus once its in, i have to move it around untill i get a good signal but as soon as i push the head unit back in it goes all fuzzy again, is there anything i can do to fix it?
the aerial cable fits into the head units socket fine, nice n tight, but i have to bend n move the actual cable around for it to go clear
it was fine with the standard clio head unit.
Is there anyway i can access the back of the head unit once it is inside the dash? cus maybe i can move the wire around. maybe a small hole/gap leading to the back of it?
If you take the top of the dash off you may be able to get to the back of the headunit, you could with my Kenwood unit.
