I've had non-standard wheels (17's) on my dynamique dci for 3 years now - no probs. with anything such as suspension (lowered 40mm), shocks etc. after 55K
BUT the custom re-map and K&N improved it more :-O
On a Ph1 but same car....Spacer is a bit of metal the goes between the rim and the hub on the car to move the wheels out say 10mm or what ever you want....ive got 10 mm spacers on my rears as car is lowered 40mm
1.2 grand pile of s***e.....Well once you stick the wheels on it youll want to lower it cause it will look like a monster truck, YOu wont need spacers if your not lowering it but youd be better to put them on if you do
