Morning Forum
This is my first post here. so hello all
I wonder if someone can help/ suggest what to try next. when i go to start my car the pre-heat coil light on dash stays on all the time doesn't go out. When the weather is cool, it was 6degrees this mornnig my car took ages to start. Had to turn over a few times and give it some trottle which gave out a nice cloud of white smoke. When warm start perfect.
I have checked glow plugs getting 0.2ohm with multivolt thing. Also took them out and checked relay was working (not sure how long they need to stay on only tested they glowed for 1/2 secs). I have cleaned egr value and hopefully put it back together correctly. Cleanned tdc sensor (no idea if working or would cause problem), put some injector cleanner in fuel tank. no difference. Taken all fuses out of fuse box side on battery and cleanned them.
Can anyone suggest anything else to try? Somebody have told my to change fuel filter, would this cause the light to stay on, also its in a black plastic box do you just replace lot of does it come out?
Thanks in advance, hopefully can get it sorted without the use of a code reader.
James
James
