Clio GT Slight Grinding changing into 4th
Hi guys, was looking at a Clio GT tonight with a view to buying it. Whilst taking it for a test drive I noticed that there was a very slight grinding when changing into 4th gear. Only happened for 4th, and by no means a struggle to select the gear, just a little 'grumble'. Does anyone know what this might be or does the car need a gearbox? And what might that cost?
markfishy
ClioSport Trader
  So many but not mine
Hello Phil, Shame there is no noise track on here lots of problems would be easy to solve. Now there's an idea. Threads with sound.
To try to understand the noise grinding grumble.
Where you changing gear quickly or steady, was it worse if you changed gear quickly, and better if you paused slightly as you selected.
Was it gears grating as they meshed, this would be a weak synchromesh on that one set of gears. 4th
If that is the case its got a limited life. very approx. 5000 to 10000miles before the change will get really noisy, then the gear will jump out when coasting off power and eventually jump out when on power. If that all makes sense?
Normally 2nd and 3rd gears are the first to wear the synchromesh out.
Second hand gearbox £200 but about 6 to 8 hours labour to fit it.
Sorry I cant be sure without the car here.
regards mark
