clio immobiliser problems !!!
  clio 1.2 dynamique
I have a Clio 1.2 dynamique was fine all day until I came to unlock the car and the button pressed straight through. I took the key apart and the button had fell off the transponder chip inside so i glued it back on to complete the circuit. it unlocked n locked the car fine but when i turned the ignition the immobiliser light was flashing and wouldn't turn over :(. the lights, stereo, heater and everything else works fine. I've been in contact with a few people that said its Renault only.
any ideas anyone ??????
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
The actual 'S4' immobiliser transponder "chip" isn't fixed to the PCB... see images below (I know your key will look different but it'll be a single button RF MkII keyfob)...
The S4 chip has most likely fallen out when you've broken the case open and if it is the case I hope you haven't used to hoover lately cos if you can't find it, it's a trip to the dealership for you asking for a new keyfob and coding session... and they'll need the car! Retail price for supply and coding was around £120-140iirc and can only be done by a main dealer or by someone with access to a Clip (Though an independent auto-locksmith might be able to code up a "Virgin" S4 chip for you if their equipment will allow UCH access)
Mick
I had a similar problem last year with key fob not disarming immobiliser. I was told when you open the fob if it isnt closed within a very short time the key need reprogramming to the car. To do this i needed the immobiliser code which you put in through the central locking button inside the car when you have done this you can reset your key so it and the car's signal match. http://www.bba-reman.com/content.as...ult_Key_Immobiliser_failures_emergency_recode
This site will give you the code for your car and therefore save you having to pay rip off renault garages. It also gives you instructions on how to find and enter your code then reset your fob. Hope this helps
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
AFAIK that link only relates to early remote CL keys with IR transmission and NOT RF Keys
Also, you can leave the battery out of an RF key for days and it will re-sync itself as its physically paired to the UCH of the vehicle... this can only be done once which is why 2nd hand keys cannot be re-paired to another vehicle despite what eBay adverts may lead you to believe.
