Clio just dies when hot
Clio 2001
1.2 16v
Starts first time runs perfectly for 20 mins then just dies....
You then have to wait for 20-30 mins for it to cool down (not overheating just normal running temp)
When it dies has no spark.....
Fitted new coil pack... (didn't help)
Going to fit new crankshaft position sensor tomorrow...
Anyone think of anything else that could be causing this....
  clio 172 phs1 turbo
Hey bud so if the temp gauge not goin above the half way point my guess would crank sensor first or just a guess when I had my 1.2 16v had similar fault with engine earth cable causing to much resistance when it was hot if ur good with a multimetre do a little resistance test between the earth cable and make. sure there clean and not loose and also with fuel pump earth. When it dies again turn the ignition off then on again with out tryin to crank the engine and listen out for the fuel pumpbuzzing under the back seats trying to prime for a few seconds. If theres no noise check the feeds the fuel pump
