clio mk3 cup fitting cobra seats
Car  Clio cup 200
Hi chaps, i have just purchased a clio cup 2010 mk3 for track days, i have also purchased a pair of cobra sebring seats, i am a bit wet behind the ears when it comes to seat fitting, so far all i have is the seats, i know i need subframes, what else will i need? airbag resistors? for side airbags? a break down of everything i need, and a point in the direction i could purchase would be great, thanks
Seats, sub-frames, runners (if you want back & forward), side mounts (if not base mounted seats), high tensile bolts, nylock nuts, washers, airbag resistors, harnesses...
We used omp subframes and sidemounts no sliders. We had to redrill the subframe to side mount fixing holes.
Sidemounts directly to the floor sounds good but you will need to lower the Steering column to get a decent driving position
Rentune do side mounts
https://m.facebook.com/rentune/
