Clio Mk3 problem
Car  Clio Dynamique S 138
Hi all,
My driver's side electric window is acting strangely. The one-touch doesn't work and the window only moves a few cm then stops, so I have to keep pressing the switch on/off to get the window fully down/up. The passenger window is fine. I'm thinking it's a switch or regulator problem?
you can reset the way it works i believe, unless its just on meganes. hold the window switch in the close position for around 10 seconds i believe. works on a megane unless the controller is fubarred.
Just fixed it. This is how I did it;
1. Open window fully
2. Hold switch in full down position (until you hear the click) for 10 seconds
3. Close window fully
4. Hold switch in full up position (until you hear the click) for 10 seconds.
Seems to have fixed it for now, slightly strange how it randomly broke itself.
