Hello, I have a clio 172 that doesn't get used alot, had a flat battery and has been sat a while. Put a new battery on it the other day, started and ran fine. Came to start it the other day. It cranks for as long as you hold the key, but won't start.
The immobiliser light flashes fast while cranking, is this normal?
If its not immobiliser I'm presuming it's crank sensor as the the pump is priming.
