Clio Ph2 Steering wheel
  Renault Clio mk2
Hello - so last week my Clio Ph1 failed MOT on rotten inner sills, so I bought my self a Clio Extreme 4 so swapping my bits over,
The Question I have
Which plug do I need to put the resistors in to remove the airbag light cheers ?
Brigsy
  T.Turbo
You can buy a clone clip off ebay £120ish. Might be somebody local to you who will do it for a few quid, where abouts are you based?
TheBandit
  Monaco172, Green1.2
Resister suggestion from Dr Jekyll and 1812lsd is 3.3ohm.
{ https://www.cliosport.net/threads/airbag-light-a-permanent-fix-for-those-with-buckets-or-aftermarket-wheel.603613/ }
At lot more sketchy than a reprogram but then a lot cheaper, I have seen quite a lot of people run resistors on wheel swaps without issue, but I guess you don't know until you try it.
edde once posted a comprehensive look on the subject here:
https://www.cliosport.net/threads/fao-ppl-with-bucket-seats-airbag-light-on-dash.190943/
