no you have to take it off from the inside by undoing and pulling the plastic liner off the bootlid, then there are three 10mm nuts that you have to undo then just pull (quite hard) at the handle with the badge on off, then get a soldering iron and melt the three pins that hold the badge on (refit either glue or melt pins) ive taken mine off before only takes 20mins
hopefully that makes sence
