Clio V6
  GTR
Looking at purchasing a Clio V6 ph2, the car I am looking at has done 54k and is silver - #26.
Any advice on things to look for when I view it would be great. It needs a cambelt and service which I am budgeting £2k for.
Also any previous owners of it on here?
Appreciate any help, A
Bluebeard
  Whichever has fuel
Rust. I wouldn’t go near a V6 (or a more expensive 172/182 for that matter) without being able to see it on a ramp.
they’re old now, and French. With a lot of plastic hiding the metalwork.
cambelt seems to always turn in to a clutch as well. (Engine is out so it makes sense)
clioV6.net may be able to help you more 👍
make sure you carry out a HPI check and also a history check from the likes of V Check.
  V6 255, 172 cup, ph1
Car is already being discussed on the V6 forum!
They can rust....
  Clio with a body kit
Personally I’d allow a little nearer to £3k if you are planning on keeping the car, you probably could do the cambelt for £2k but It was a lot easier to sort everything out at once for me than travel back to the specialist to sort any future problems. I’ll attach the parts that i did when in for the cambelt.
Good advise above tho. Check v6clio.net if your not a member the forums membership cost is worth it for any advise you may potentially need.
What's it like with the TTV? Picking mine up Thursday after a TTV and quaife
