Clio Williams 1 Rear Ride Height Problem
  Clio 182
This is probably a common issue but tried searching forum and not found what I need. I have a Williams Clio 1 -2.0 with uneven ride height at rear, can someone advise two things please 1) Standard Ride Height, 2) How to adjust it?
  Clio 182
Its a torsion bar. You need to remove the torsion bar with both wheels in the air and then get both rear wheels the same distance from the same point on the arch. You should be able to find some decent instructions on the web if you google it, might not be for a willy but they are all roughly the same idea.
As for standard height when I raised my old one up (because the previous owner had slammed it into the deck) from memory I just dropped the rear axle as far down as I could get it with the shocks attached.
Good luck!
  182
Big rubber bush collapsed on mine there is one each end. Behind where the torsion bar pulls out.
Renault never done these bushes seperat as it was an intergrated part of the rear beam.
So i changed the whole beam.!!
