clunking
  172 sport
from standstill when im setting off im getting a clunking noise,seems to be coming from the middle to back of the car,also get this when reversing,when im driving though its fine,no clunks....anyone?
  williams 2 turbo
sounds like an engine mount gone to me, as you load it up as you pull away it moves, and when your moving it does'nt? that sound about right?
to try it out drive slowly and then give it a pasting and it should make the same sound. if it does then a engine mount is buggered
P
pete.grant
I had the exact same problem with my old Saxo after a new exhaust was fitted. Turns out the garage did not fit it correctly so it moved about but I only ever noticed it when pulling off. Took it to another garage who found that the original garage had used the wrong bolts to hold it together. Never had any issues with it after that.
  172 sport
update,ive had the dog bone mount changed and also the passanger side ball joint has been changed......the clunk noise is still coming from the passanger side footwell,it is pretty loud whilst you are in the car...if i set off really slow it dosent do it,when i set of normal to fast it will clunk...not sure what else to look at.
get the passenger side mount checked for damage also the gearbox to subframe one then check the engine isn't catching on rack etc.
  172 sport
update....ok then....garage rang me today and they can hear the noise on the road rest,but they said when they get it up on the hoist they can not locate were the noise is coming from,they said they have checked everything,they want me to take the car and keep driving it till problem develops more..so far they have changed dogbone mount,and balljoint....they said they have checked all mounts....can anyone shed any light on this for me please..
  A4 DTM/iceberg cup
is it the rear brakes like my old saxo? when i park the car on a slope using the handbrake. when i come back to it and move off the pads are still in contact with the disc and then release! noticed my clio does it as well if the brakes have been hot when i stop!!! just an idea.
  172 sport
dont think that will be it...it dfoes it from cold on a morning...doing it all the time..im sick of it...
