Clutch change - diaphragm springs already compressed.
loggyboy
Just done a clutch change on my 182, For some reason the diaphragm springs seem to be compressed without the release bearing even touching them. This means when I depress the clutch the 1st 70% of cable/release bearing movement doesn't nothing, and when it does press the diaphragm, its not enough to disengage the plate.
Its valeo clutch and all kits matched up when I checked them against the old one.
This is the 2nd ive done over the years and first gave no issues,
Any silly mistakes I could have made?
  dan's cast offs.
sorry, kind of misread it. have you checked the daft things first, box seated ok? cable located as it should be?
