clutch fitting?
Car  fiesta 1.25
my clutch came today thanks again maxx and i need to fit it asap but im not sure what im doing.is it easy and has anybody ghot a guide?chris
Socket set, axle stands and a jack minimum really. Stuff your likely to forget you need are 30mm socket, 8mm square drain plug. Not forgetting fresh gearbox oil, drain plug washer aswell for about a quid.
Book times about 5 and a half hours but it shouldn't take that long.
as far as i know it is not an easy job and involves lwering the engine so that you can take the gearbox out! do you even own a set of tools?
You just support the engine with a jack and pull the g/box out from the top, its just a case of unbolting everything, driveshafts, mounts etc
