Clutch for Mk1 V6
Car  V6 Mk1/Beat/E320/Mcoupe
Anyone know where I can buy an aftermarket clutch for the Mk1 V6?
Thank you
Drop Yozza or fred on here a message they're working on one at the moment or drop MikeT a message as he runs an uprated one.
NO ONE, and i mean NO ONE does a replacement clutch
Wideboy Mike is running a std item
i'm trying to get one made
so are you making one?
yes and no.
we are developing a solution to the problem Klio, but No, we do not have a current solution to the clutch issue.
ap / helix & everyone else do not make one at the moment. The sadev trophy clutch is a smaller unit, so it is either standard replacement, or part of a larger transmission package.
/y0z
so if i need a clutch, where can i get one and how much will it cost me?
whats the sadev trophy clutch?
Smokey said:
If mikes runs 400brake and is on the standard one, whats the problem?
it eats clutches.
LOL
/y0z
renault dealer / matt at Specialalist Renault Breakers (j3ned)
cost - don't know off the top of my head, haven't got prices with me.
sadev 6 speed sequential gearbox from the v6 trophy race car.
/y0z
Clutch is definitely the weak point on the Vee!! Even without the monster power of Mike's the standard engine is plenty enough for the clutch. I only tried the 4k revs dump the clutch trick the once ... it slipped like a mofo and stank. Will definitely be a market for uprated clutches as we all start wearing ours out ;).
klio said:
so we can use the trophy clutch in the manual 6 sp gearbox?
no, that is what i said up at the top. you can't use it, as it is a different clutch.
there is nothing on the market for the V6 apart from the standard clutch.
/y0z
Uprated cover definately required - launching with standard is a one off affair even with as little as 300bhp - beyond that it even slips on gear shifting.
Huger do an uprated center plate for 500 euros - nice
Mike
The clutch is surprising weak. I just took it to track over the weekend, on the way there I was going 120-140mph for quite a distance, then when i stopped, the clutch was gone. The pedal was stuck to the floor. I rested it a little then it came back. Then on the track, every few laps it did that again. The clutch was just gone. I changed the Clutch fluid and it went away, but then the clutch just felt shitty afterwards.
does anyone know how else i can reach j3ned? PM's him and still not reply yet.
Thank you
