clutch grinding (part 2)
Car  Not a Clio
i think ive found the problem
clutch pedal is very wobbly from side to side, if i push the pedal in applying pressure to push it to the right at the same time... no grating/grinding
so im thinking something has snapped off or something and the pedal is going down off center?
What holds the pedal in place to stop it moving from side to side?
Si.
ok well i sorted the problem myself...
where the cable comes through the grommit in the bulkhead there was a little plastic sleeve loose above the grommit so i assumed this sleeve was supposed to sit inside the grommit... so i worked it back in and the grinding/grating has gone.
Si.
