clutch judder
  RARE Unmolested Corsa sxi
does it judder when fully on, or when you are releasing it when going into gear?
  Mondeo TDCI 130
Could be due to something leaking onto the clutch also, ie rear crank seal leaking oil onto it, does it get better the more you drive? Either way the clutch will need replacing by the sounds of things.
  CLIO 172
it only does it mainly when its cold when it warms up it dont seem to do it as much it goes in gear fine it just judders when i release the pedel
